  New Posts New Posts RSS Feed - Pin 1 Polarity Markers In FP Designer
mahmoodv99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mahmoodv99 Quote  Post ReplyReply Direct Link To This Post Topic: Pin 1 Polarity Markers In FP Designer
    Posted: 25 May 2016 at 8:51pm
Pin 1 Polarity Marker is wrong in FP Designer when the footprint is mirrored horizontally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 5:56am
When you place Polarity Marking, it stays at the coordinates that you placed them at.
If you what to relocate them, Right Mouse Button (RMB) and select "Shapes".
Then select the Polarity Marker with Double Click or Single Click then RMB select Properties.
Then change the Positive "X" location value the Negative by adding a minus "-".
Then select Apply button to see if the Polarity Marker is where you want it. Adjust the X, Y coordinates accordingly.
Then select the Finish tab and the OK button to finalize the editing.
Then select the entire row of the FPX file if you want to overwrite the data in an existing row.
Or just select the "Add to Lib." button and enter a new row in your FPX file.
