Footprint Expert Physical Description |
Post Reply ![]() |
Author | |
m.elsayed ![]() Advanced User ![]() Joined: 22 Sep 2016 Status: Offline Points: 65 |
![]() ![]() ![]() ![]() ![]() Posted: 15 hours 35 minutes ago at 12:29am |
I have noticed that as screen shows Footprint Name uses the D1 dimension instead of D.
Please can add more details, also how is the Physical Description generated?
Footprint Name: QFP50P1600X1600X120-100 Physical Description: Quad Flat Pack (QFP), 0.50 mm pitch; 100 pin, square, 25 pin X 25 pin, 14.00 mm L X 14.00 mm W X 1.20 mm H body |
Tom H ![]() Admin Group ![]() ![]() Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5860 |
The footprint name describes the outer dimensions of the package.
The 16.00 mm = the Lead Span per the IPC-7351 Naming Convention Guidelines. The 14.00 mm = the Physical Description of the Package Body (doesn't include the terminal leads, just the package body dimensions). |
Post Reply ![]() |
Tweet |
