PCB Model Selection Confirm - Molded Body |
m.elsayed
Topic: PCB Model Selection Confirm - Molded BodyPosted: 12 Feb 2026 at 10:56am |
For this part” TAJB685M025RNJ” in this datasheet “http://download.siliconexpert.com/pdfs2/2026/1/22/22/20/26/9847155927/avx_/manual/taj.pdf” What PCB Model should we use to create
Footprint ? Is it “Molded Body”? Correct or
wrong |
Posted: 12 Feb 2026 at 4:31pm |
It is a 'Molded Body' package if the 'D1' dimension is at least 0.60 mm less than the 'D' dimension.
![]() If the 'D1' dimension is less than 0.60 from the 'D' dimension, then it's an FP Designer footprint. |
m.elsayed
Posted: 14 Feb 2026 at 9:57pm |
1. Please add more detail is that generic rules for similar case if the 'D1' dimension is less than 0.60 from the 'D' dimension, then it's an FP Designer footprint.
2. Also in FP tab, create it normal and after that choose to transfer to FP tab, or I must create it from scratch in FP tab
Posted: 15 Feb 2026 at 11:45am |
If D1 is less than 0.60 then start in the Molded Body calculator with most of the dimensions and the mfr. recommended pattern.
Then move the footprint to FP Designer and fill out the 'Specifications' panel and edit the Body dimensions and pad stacks as needed. |
