  New Posts New Posts RSS Feed - Paste Mask Rules For Thermal Pads
manu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote manu Quote  Post ReplyReply Direct Link To This Post Topic: Paste Mask Rules For Thermal Pads
    Posted: 20 Mar 2019 at 4:16am
What are the exact rules for the thermal pad solder mask ?
I know that it is 50% of the pad but from what size the mask is divided by 4 or more rectangles ?
And what is the rule for the distance between these small rectangles? and the distance between these rectangles and the edge of the copper pad ?
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 8:36am
The Thermal Tab Rules are located in the "Preferences > Rules" section of Library Expert.
  • Thermal Tab Solder Mask (+/-)
  • Thermal Tab Pattern Defined Solder Mask
  • Thermal Tab Paste Mask %
  • Thermal Tab Minimum Pattern Space
You define the Thermal Tab values that are best for you to create a custom library that matches your preferences.
Solder Mask Defined Thermal Pads are a new IPC-7093A standard.
See this forum post -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 4:19pm
Here is an image of the Minimum paste mask aperture spacing rules for a SON package with a Thermal Pad that intersects with a row of pins.
