Paste Mask Question |
vavouris
Topic: Paste Mask QuestionPosted: 24 May 2018 at 5:50am |
I'd like to ask what is the general guideline for paste stencils. Should the stencil be same size as the pad, smaller or greater? I know that in BGA packages we want very few solder paste on the pad. And on other packages, I was creating a paste mask figure 70% of the pad. I am a bit confused now, and I don't know if should continue to do that or leave it 1:1 and let the assembly plant deal with it. Thanks, Theocharis
Posted: 24 May 2018 at 6:08am |
For Standard SMD pads the Paste Mask aperture size is 1:1 scale.
For Thermal Tab pads the Paste Mask Reduction is between 40 - 60%. |
vavouris
Posted: 24 May 2018 at 6:15am |
Thank you! That was fast.
Posted: 24 May 2018 at 6:19am |
If you use Rectangle Pad Shape, the Paste Mask aperture will be Rounded Rectangle, so you might as well use Rounded Rectangle for the pad shape too.
