  New Posts New Posts RSS Feed - PADS Part-Type Name in Batch Create Mode
JZsori View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JZsori Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2013 at 8:21am
Also looking forward to 2013 version.  Appreciate all your efforts.
jameshead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jameshead Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2013 at 8:30am
Pulsonix has a built-in attribute called <Logic Name> that's used to enter the pin function of an IC pin, or the polarity of an electrolytic capacitor or diode.
On my footprints I add the <Logic Name> attribute on silkscreen and assembly drawing layers for the +ve pin of an electrolytic capacitor so it's moveable when editing the silkscreen, and when moving it the component the attribute is tied to is highlighted.
I wonder if the Pulsonix PADS import would recognise the PADS equivilent you describe and be able to deal with it?
Currently Pulsonix will recognise the "Ref.Des" appearing in PADS ascii and map it to <Component Name>, and also recognise "Part Type" and map it to <Part Name>.
Presumeably if the PADS attribute you're talking about appears in a similar way then Pulsonix may already be able to handle it (just that I've never seen it before in a PADS ascii output).  If it isn't able to handle it at present a nice word to the Pulsonix Developers at WestDev may get it added.
Something worth looking into in the future.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 11:01am
Was this feature implemented to your satisfaction?
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2013 at 5:23pm
Was PADS Layout "Part Type" name added to the batch library function?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 6:21am
Our idea was to use the FPX file mfr. "Part Number" column in the FPX file to auto-generate the "Part Type" and the "Footprint" column to auto-generate the "Decal" name.
The problem we ran into is that only PADS Layout has this issue (it's unique to PADS).
So we're still tinkering with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 6:29am
Would it be possible to just create a new column with a specific name like Pads-Part-Name and if the software sees you are generating pads decals it then can look for a column with that name to get the different part name. This way it only happens when generating decals for pads ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 6:35am
Please work directly with Chris Arnold on this feature.
Chris is currently on vacation until the end of the month, but you can email him and he will respond.
Chris is the CAD tool interface software programmer and can just about do anything with the program, but we need to involve other PADS customers too so that we implement something that everyone can live with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 6:39am
Thanks Tom,
I will email him. Also we talked about adding other defaults to the pads interface that were missing. One item was text orientation . You had mentioned this would be implemented . Is this still a plan ? Should I just list what I would like to see and send it to Chris ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2013 at 6:51am
Chris Arnold is the CAD interface programmer. All features that are unique to any CAD tool need to be approved and implemented by Chris.
What we need for each CAD tool is a separate GUI control panel with all the unique features for that CAD tool. Example: Allegro has many features that other CAD tools do not have and Chris needs to create an Allegro Control Panel to allow Allegro users to program the custom feature like "No Probe Test Point Keep-out" or "Place Bound Layer" or "Mechanical Pins", etc.
This needs to be created for every CAD tool, not just PADS.
Chris's email is: first name dot last name at pcblibraries dot com (if I post his email address in the forum it will be picked up by junk mail search bots and he'll be bombed with unnecessary email).
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2013 at 7:28am
I realize you are all busy but I have sent two emails to Chris without a response in regards to additional features to the pads interface. If you are not planning to add any changes please let me know .
Thanks!
Lenny Alexman
