  New Posts New Posts RSS Feed - Pad to Pad vs Pad to Thermal Tab
dramos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Topic: Pad to Pad vs Pad to Thermal Tab
    Posted: 02 Mar 2022 at 7:49am
Hi to all,
Could anyone explain me why the minimum distance between pads should be different to the distance between pad and thermal tab?
I cannot understand it both are copper and from the point of view of the pcb construction should be the same, isn't it?
Thanks for your comments.
Regards.
dramos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2022 at 9:51am
You can change the Options to whatever values you want.
The pin to pin 0.15 minimum distance would allow a 0.0375 (1.5 mil) solder mask swell and have a 0.075 mm solder mask web in-between every SMD pad.
Ask your fabrication shop if they can handle a 1.5 mil solder mask swell.
Or ask your fabrication shop if they can handle a 0.05 mm solder mask web. Then your solder mask swell can be 0.05 and the solder mask sliver can be 0.05 and you will have solder mask in-between every SMD pad.
The Pin to Thermal clearance was established by the component manufacturer's recommended patterns.
All mfr. recommended patterns have a minimum pad to thermal space of 0.20 mm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dramos Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2022 at 12:27am
Dear Tom,
Many thanks for the explanation.
What I understand from it, it is that we always should try to place mask between Thermal pad and pin pad.
The recommendation of the manufacturer is to reduce the thermal pad
The component has a thermal pad of 1.6mm +/-0.15mm and the thermal pad on the component is only 1.5mm and due to this the distance of pd to thermal pad is bigger than 0.2mm.
I think that I've seen a reduction of the solder mask swell, placing mask over the pad but I think that it would be something special and the manufacturer will explain it on each datasheet.
It is really grateful to learn from you
Best regards,
dramos
