  New Posts New Posts RSS Feed - Pad to Pad space in 3-pin SOFL
Batiskaff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Topic: Pad to Pad space in 3-pin SOFL
    Posted: 03 Mar 2021 at 2:47am
In Rules "Pad to Pad" spacing = 0.15mm
But pads were trimmed and now Pad1 to Pad2 space=0.33mm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 10:08am
The Pad Stack Rules are intended for medium to large packages.
You can't have a pin pitch of 0.175 when the maximum lead thickness is 0.23. That's impossible.
Turn the minimum pad to pad off for micro-miniature packages. The pin pitch is 0.175. This can't be true. The pin pitch is between the Center of the Body and the center of the pin. You need to double to pin pitch to 0.35 mm.
But I would also change the solder joint goals downward slightly.
Please provide a link to the datasheet URL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Batiskaff Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 11:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2021 at 12:13pm
This package in not a SOTFL.
The SOTFL component family has the Terminal Lead Width the same size for all leads.
This JEITA-SC-1168B case code is none standard and must use the mfr. recommended footprint.
Package:
Mfr. Recommended footprint:
This page was generated in 2.953 seconds.
