  New Posts New Posts RSS Feed - Pad Stack Manager FPX 2012.18
Maarten Verhage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maarten Verhage Quote  Post ReplyReply Direct Link To This Post Topic: Pad Stack Manager FPX 2012.18
    Posted: 06 Sep 2012 at 1:59am
Dear professor Tom,
I’m currently evaluating the Footprint Expert. My first task is to make a BGA footprint for an Altera FPGA.
I’m running version 2012.18 now, with Windows XP. I know about your statement of “may work, but unsupported”
In the Pad Stack Manager the parameters section of the dialog for Top, Mask Top and Stencil Top are all greyed out, is that intended?
In the Pad Stacks section I can create a new padstack. But I am unsure about the indented use of this by your development team. Could you explain more?
What I want is maximum control over all the shapes in every layer, including the recommended Bow Tie aperture in the IPC-7525A Stencil Design Guidelines.
Wouldn’t a delete button a good idea to remove a padstack?
Furthermore the padstack name is lost when I ok the dialog and reopen it. But the field remains selectable and the parameters are remembered.
Another thing: In the Setup drafting options I changed the user preference for Silkscreen outline width to 0.2 mm, saved it and later in the BGA Wizard the previous 0.12 mm parameter is loaded. Have I missed a preference setting or doesn’t FPX behave as expected.
Thank you very much for your attention and time!
Best regards,
Maarten Verhage
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 7:56am
The Padstack Manager is not completed yet. We are currently focused on creating all the Through-hole component families and they should be completed by the end of 2012. Once all the component families are completed we'll back-track and complete the Padstack Manager.
Whenever you change any "User Preferences" in "Setup > User Preferences" you must also change the Environment Setting to "User" in "Setup > User Preferences > Design Tab > Environment". Then when you're in the Calculator, in the main toolbar "Environment > Drop-down > User". Then all of your personal preference settings will appear in the graphic viewer.
