  New Posts New Posts RSS Feed - Pad size controll
Pad size controll
tccab View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tccab Quote  Post ReplyReply Direct Link To This Post Topic: Pad size controll
    Posted: 06 Jul 2015 at 11:23am
Will setting Surface Mount Environment in the User Preferences to other than Nominal give me larger or smaller pads during Build Part? Is there a way to compensate pad size for processes like Wave vs Reflow?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2015 at 12:04pm
Absolutely. You can create a Wave Solder Preference Rules file and open up the "Terminal" tree and set all the Toe, Heel and Side solder joints in the Density Level tab.
You can create as many preference rule files as you want. Just open any Rule file and process every part in your FPX file to Batch build a custom library with a unique Footprint Name Suffix.
