  New Posts New Posts RSS Feed - Output file name?
Output file name?
Matthew Lamkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matthew Lamkin Quote  Post ReplyReply Direct Link To This Post Topic: Output file name?
    Posted: 29 Oct 2012 at 3:58am
When building a selection based on a single component the name defaults to "New_Parts" always.
This can overwrite existing data and requires the user to change the name.
In order to keep the output name the same as the footprint name the footprint name has to be selected and copied "before" building the footprint as you cannot go back to it.
So can it be made so that when making a single new part the library name matches the footprint name (perhaps as an option).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2012 at 6:24am
Don't "Build a Selection" for a single part.
"Build a Selection" was intended for "Batch Build" of 2 or more parts.
Open a single part into the Calculator and use "Build Current Footprint".
