  New Posts New Posts RSS Feed - OrCAD PVB 17.2 - No psm, Because Duplicated RefDes
DSchaef View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSchaef Quote  Post ReplyReply Direct Link To This Post Topic: OrCAD PVB 17.2 - No psm, Because Duplicated RefDes
    Posted: 25 Jan 2017 at 4:40am
I'm trying to evaluate the basic usage of your tool. Therefore I'm currently using the Lite version.
I found out, that I can't get a working footprint in OrCAD 17.2 without doing manual work.
Basiclly OrCAD complains, that there are two text blocks ("Dev" and "Ref") on
class: REF DES
subclass: ASSEMBLY_TOP
And in the graphics, you can see that OrCAD 17.2 is right about the two text blocks.
Here are the logs:
WARNING(SPMHA1-299): Create symbol multiple text lines are not supported on a single component type subclass.
    Item=1, Text= 'Dev' Layer= DEVICE TYPE/ASSEMBLY_TOP Location= (0.0000 0.7500)
    Item=2, Text= 'Ref' Layer= DEVICE TYPE/ASSEMBLY_TOP Location= (0.0000 0.0000)
And in the journal file I can see:
\i (00:00:10) Label refdes
\t (00:00:10) Pick text location.
\i (00:00:10) setwindow Form.mini
\i (00:00:10) FORM mini text_block 3
\i (00:00:10) FORM mini angle 0
\i (00:00:10) FORM mini mirror NO
\i (00:00:10) FORM mini text_justification Center
\i (00:00:10) FORM mini class REF DES
\i (00:00:10) FORM mini subclass ASSEMBLY_TOP
\i (00:00:10) setwindow pcb
\i (00:00:10) pick 0 0.75
\t (00:00:10) last pick:  0.0000 0.7500
\t (00:00:10) Refdes of this subclass is already defined, change subclass.
Regards
Daniel
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 11:57am
What does your layer mapping look like?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DSchaef Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 6:28am
It's the default mapping:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSchaef Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 6:53am
I can understand that supporting non-paid version is not possible. It's just that I'm not sure if this is a bug or a setting/support problem, so it's hard to evaluate if it is worth to buy the program. Cry
For a non-paid program this issue is a non-brainer, no problem at all.
For a paid program I would expect an automated flow without manual rework.
Could you just point me to the right direction:
- Is this a bug (which I don't expect to be fixed for me as a non-paying user!)
- Is it my usage of the tool, which would need more detailed support (again: I don't expect support as not-paying user)
Regards
Daniel
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 9:44am
Which version of FPX are you running?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSchaef Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 10:08am
Hi Chrisa_pcb,
I'm running 2017.06.
Regards
Daniel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 10:11am
You need to download V2017.07.05 prelease to check the bug fixes.
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 10:14pm
If you do a search through the main .scr (it'll have the same name as the footprint) for '# Labels' you'll see the section which adds the REF and DEV and it should look like this:
# Labels
Label refdes
setwindow Form.mini
FORM mini angle 0
FORM mini mirror NO
FORM mini subclass SILKSCREEN_TOP
setwindow pcb
pick 0 0.75
Text "REF"
done
setwindow pcb
Label refdes
setwindow Form.mini
FORM mini angle 0
FORM mini mirror NO
setwindow pcb
pick 0 0.75
Text "REF"
done
setwindow pcb
Label device
setwindow Form.mini
FORM mini angle 0
FORM mini mirror NO
FORM mini class DEVICE TYPE
setwindow pcb
pick 0 0.75
Text "DEV"
done
The big question being why your Ref Des is apparently going to ASSEMBLY_TOP subclass on both, and not SILKSCREEN_TOP on the first. The way its setup you should have a Ref Des on each ASSEMBLY_TOP and SILKSCREEN_TOP, and then the DEV goes only to ASSEMBLY_TOP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSchaef Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 1:51am
Thank you both for your help Clap
