  New Posts New Posts RSS Feed - OrCAD 17.2: END LAYER Regular Pad Is Undefined
dmonca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmonca Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 10:28pm
Works now fine with .11 Tongue
I have another issue though, concerning the markings for pin 1.
When checking the "Autogenerate Pin1 Indicator Line" in Drafting->Legend and "Include Polarity Indicators" in Drafting->Assembly and then generate the part (press OK), the Pin 1 markings are generated fine.
After saving the part to the library and reopening it, the markings have dissapeared.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 7:17am
If you want permanent Legend and assembly polarity marking, you need to set them up in "Preferences > Drafting > Legend > Pin 1 Polarity Dot > Size"
However, we prefer that you use our custom polarity marker feature that has 8 different shapes -
Download the documentation -
Watch a very short video -
Remember that the same technique can be used for both Legend and Assembly Drawing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 7:22am
V2016.11 Library Expert will be officially released today.
  • Pro
  • Lite
  • POD Builder
  • Viewer
  • IPC Calculator
This is expected to be the last 2016 release as we prepare to release V2017 in October.
shreyas.shroff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shreyas.shroff Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 12:57am
Can you provide me the process of how to fix this issue? I am unable to understand the fix
Warning: NO internal pads defined
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 12:51pm
Are you using Allegro or OrCAD PCB?
This page was generated in 1.414 seconds.
