  New Posts New Posts RSS Feed - OrCAD 17.2: END LAYER Regular Pad Is Undefined
dmonca View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dmonca Quote  Post ReplyReply Direct Link To This Post Topic: OrCAD 17.2: END LAYER Regular Pad Is Undefined
    Posted: 13 Sep 2016 at 6:28am
We recently updated our OrCAD PCB-Editor to 17.2. Now LE can not build TH footprints anymore. The new Padstack Editor always throws up this warning:
This is the script that caused the error (just as an example, since all others behave the same way):
# Allegro script
# Generated by FPX Expert
#   name:       s218h145
QtSignal MainWindow New triggered
QtSignal fileNewDialog dataCombo CurrentIndexChanged "Thru Pin"
QtSignal fileNewDialog dataCombo activated "Thru Pin"
QtSignal fileNewDialog browse clicked
QtFillin s218h145.pad
QtSignal fileNewDialog OK clicked
QtSignal MainWindow Units CurrentIndexChanged Millimeter
QtFillin Yes
QtSignal MainWindow DecimalPlaces activated 4
QtSignal GuidedDrillTab HoleType activated Circle
QtSignal GuidedDrillTab holeXSize editingFinished 1.45
QtSignal GuidedDesignLayersTab LayersTable cellClicked 0 "Regular Pad" None 0 2
QtSignal GuidedDesignLayersTab PadShape CurrentIndexChanged Square
QtSignal GuidedDesignLayersTab PadShape activated Square
QtSignal GuidedDesignLayersTab PadWidth editingFinished 2.18
QtSignal GuidedDesignLayersTab LayersTable cellClicked 1 "Regular Pad" None 1 2
QtSignal GuidedDesignLayersTab PadShape CurrentIndexChanged Circle
QtSignal GuidedDesignLayersTab PadShape activated Circle
QtSignal GuidedDesignLayersTab PadDiameter editingFinished 2.18
QtSignal GuidedDesignLayersTab LayersTable cellClicked 1 "Thermal Pad" None 1 3
QtSignal GuidedDesignLayersTab PadDiameter editingFinished 2.3
QtSignal GuidedDesignLayersTab LayersTable cellClicked 1 "Anti Pad" None 1 4
QtSignal GuidedDesignLayersTab LayersTable cellClicked 2 "Regular Pad" None 2 2
QtSignal GuidedMaskLayersTab LayersTable cellClicked 0 Pad None 0 1
QtSignal GuidedMaskLayersTab PadShape CurrentIndexChanged Square
QtSignal GuidedMaskLayersTab PadShape activated Square
QtSignal GuidedMaskLayersTab PadWidth editingFinished 2.18
QtSignal GuidedMaskLayersTab LayersTable cellClicked 1 Pad None 1 1
QtSignal GuidedDrillSymbol FigureType CurrentIndexChanged Cross
QtSignal GuidedDrillSymbol FigureType activated Cross
QtSignal GuidedDrillSymbol FigureWidth editingFinished 1.0
QtSignal GuidedDrillSymbol FigureHeight editingFinished 1.0
QtSignal MainWindow Save triggered
QtSignal MainWindow Exit triggered
I have already checked the psmpath and psmpath settings and the both conatin the "." in the first place (although I don't think that this is the problem here, sinc SM Parts build correctly).
I am running LE2016.10
Any ideas how to fix this?
Regards
Daniel
tbest View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbest Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 7:34am
I've just encountered this issue as well. I deleted the last two lines in the script, which allowed me to see all the parameters the script is editing.
Currently, the script is only populating the "Regular Pad" column on the "Begin Layer" row under the "Design Layers" tab. Pad Editor isn't making the padstack because it doesn't have enough info to do so.
The same thing is occurring on the "Mask Layers" tab, but I don't think that affects the error we're seeing.
Might just have to manually add the information in Pad Editor for now.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 10:19am
Out of curiousity.. do you still have 16.6 loaded? 16.6 uses pad_designer, whereas 17.2 uses the new padstack_editor. I've had issues with 16.6 also being on my machine when trying to run 17.2. Make sure you use the Cadence Switch Release program to set the release to 17.2.
As a check, I just ran thru-hole reference parts with both square and circle pads without issue, and they mirror what you have above, so I don't think its a problem with the script. I think its getting its wires crossed trying to run the 17.2 programs. Here is what the new padstack_editor looks like:
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmonca Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 12:07am
Hi Chris
Nope. Version 16.6 is not installed. I removed it after installing the new release.
As best mentioned: Also on my machine, only the beginning layer gets its information from the script. The rest of the fields stay empty (set to "none")
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2016 at 9:54am
Try running the script manually using the file -> script command and see what happens.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmonca Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2016 at 11:11pm
Hi Chris
Unfortunately still the same behaviour.
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2016 at 11:13am
Actually... can you send me the part in FPX form? Or at the least screenshot your dimensions so I can replicate? Lets see if I can get that part to throw the error.
I'll send you my email by PM. Lets talk there so we can get this worked out.
BennsPCB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennsPCB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 4:45am
When I start the padstack_editor stand-alone, it starts in my HOME-directory instead of what I would prefer the PSMPATH-directory.
I also reported another issue concerning the missing searchpath to the binarys for "padstack_editor"
and "allegro", i.e no footprint creation at all. Cadence does not set them anymore in 17.2
/my 5 cents
jrosal View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote jrosal Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 12:41pm
I'm also getting this "End layer undefined" and "No Internal Layers Defined" warning when trying to generate through hole footprints. Surface mount footprints works fine.
I'm also using 2016.10.
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 1:52pm
Ok. I got this covered with jrosal. Here is the fix. It should be in the new pre-release tomorrow and .11 should be hitting next week.
·         Allegro/OrCAD PCB – Between builds S002 and S005, Cadence slightly modified the syntax of one of the commands used by the 17.2 scripting. A change has been made to reflect this, but it will BREAK all builds before S005. You *must* upgrade to S005 or later of Allegro/OrCAD PCB after you implement this patch. This will also fix the No DEFAULT INTERNAL issue that people on S005 were having.
This page was generated in 0.393 seconds.
