  New Posts New Posts RSS Feed - Only Body Dimension
Only Body Dimension
Bharat_Verma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Topic: Only Body Dimension
    Posted: 21 Apr 2022 at 1:56am
Many time it happens that we need to draw only component body,  For mechanical parts.
In all new cloud version its not possible to add courtyard with outline only. It requires minimum 1 pad to enable save option.
So, Can you please have a look into this .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2022 at 9:17am
What version are you referring to?
Are you saying you had that feature and now you don't in the latest V2022.06 Cloud?
Are you using Pro or Enterprise
Are you building FP Designer footprints for Mechanical parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff.M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2022 at 10:21am
Try: After the footprint is created, use the mouse click and drag to select all pins then Right Mouse Click and select Remove.
Note: if you select 'Hide' you'll get a Handled Exception error for now, but this will be fixed in the next 2022.07 pre-release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bharat_Verma Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2022 at 8:36pm
find my answers below.
We are using " Footprint Expert Enterprise Edition CLOUD 22 version 5"
It was there in PRO version 2017.
We are using Enterprise edition
YES, We need to draw body dimension to have virtual appearance on Design.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2022 at 8:12am
Download the latest V2022.07 pre-release and it's fixed.
