  New Posts New Posts RSS Feed - Older Preferences and FPX Library with 2013
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Topic: Older Preferences and FPX Library with 2013
    Posted: 29 May 2013 at 5:15pm
Why does 2013.02 load in a new directory so I have to reset my defaults and libraries?
Is there any easy way to reuse my previous settings and libraries?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2013 at 6:01pm
You should copy/paste all of your library files to the new folder.
Or you can set your Library Path in "Setup > User Preferences > Files > Library Directory"
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2013 at 3:12pm
I just tried that , reloaded the program and although is says the old directory name in the Setup options. When you go to the library it is still selects the 2013 directory.
This page was generated in 0.343 seconds.
