Oblong BGA Pads Instead of Round For 1st Row
toshas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote toshas Quote  Post ReplyReply Direct Link To This Post Topic: Oblong BGA Pads Instead of Round For 1st Row
    Posted: 30 Sep 2021 at 10:41am
In reference design special shape (narrow oblong instead of round) of a 1st row pads is applied.
How often this trick is used? What is about soldering result for a volume production?
BGA has 0.46 pitch, without this trick 3 mils width/separation is required, with it 3.7 mils width/separation is acceptable.
These traces and pads are most complicated place in particular PCB design and defines fabrication requirements for a whole project.
Default pad size is a 10mils, oblong pad has 7 mils x 13 mils dimensions.
How it can be calculated for proper soldering?
Is it possible to change size even more (6 mils x 14 mils) to get low-cost 4 mils width/separation requirement for fabrication?
Many thanks!
