  New Posts New Posts RSS Feed - Nominal With Uneven Tolerances
ransonjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ransonjd Quote  Post ReplyReply Direct Link To This Post Topic: Nominal With Uneven Tolerances
    Posted: 27 Jan 2017 at 8:00am
I've noted that Library Expert doesn't save the nominal, but calculates it as the mean of the minimum and maximum of a dimension.
I've been working with a few parts where the tolerances are uneven, and this means that the naming doesn't match the datasheet nominal. Dimensions D and E from this DFN provide a quick example.
Is using the mean value correct according to IPC, or is this a limitation of PCB libraries?
Cheers,
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2017 at 8:32am
I the IPC mathematical model, various minimum and maximum tolerances have no affect or impact on the resulting land pattern.
You can enter various minimum and maximum tolerances in Library Expert, but Library Expert will save the data as the nominal tolerance.
This page was generated in 0.660 seconds.
