  New Posts New Posts RSS Feed - Nominal/Tolerance Not Available in 2021.03 FP Pro
chads108 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chads108 Quote  Post ReplyReply Direct Link To This Post Topic: Nominal/Tolerance Not Available in 2021.03 FP Pro
    Posted: 20 Apr 2021 at 9:22am
I installed Footprint Expert 2021.03 free version this morning.
I noticed that the fields for Nom/Tol are not available to create footprints.
I have tried selecting the different radio buttons, but it makes no difference in what is available.
Is this by design, or is there some setting that needs to be done somewhere?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 9:28am
Only the Required dimensions to calculate a footprint are not grayed out.
But you can certainly enter values for Nominal and Tolerance in every calculator even though they are Grayed out cells. They are fully functional.
Which component family prevents you from entering in Nominal / Tolerance values?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chads108 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2021 at 9:32am
I see that they work now.  I didn't try to put values in the grayed out fields.
Thanks.
