Nominal Epad vs Max Epad |
| Author | ||
lsday
Topic: Nominal Epad vs Max EpadPosted: 17 Sep 2019 at 12:15pm |
Question: Why does the Library Expert calculate the Exposed center pad padstack to nominal instead of max?
Posted: 17 Sep 2019 at 12:37pm |
Several reasons:
You need to show us a component mfr. datasheet that recommends a maximum pad size. We built 2 million parts for POD and could not find any mfr. using Maximum pad size dimensions. |
lsday
Posted: 17 Sep 2019 at 1:44pm |
Thank you for your response. The old LP Wizard calculated them to max and we still have cells with those size pads. We also still use land patterns per JEDEC OUTLINES. We do not create cells for every vendor. We reuse if we think it fits.
Posted: 17 Sep 2019 at 2:12pm |
We (PCB Libraries, Inc.) created LP Wizard back in 2004.
Library Expert allows the user to enter any dimensional data that you want, both for the physical component and the Land Pattern. The end user has options to oversize, under-size or exact size. Whatever you want. No component manufacturer uses JEDEC package dimensions verbatim. We already proved that via our research. JEDEC seems to be like a Guideline. |
lsday
Posted: 17 Sep 2019 at 2:58pm |
Yes you are correct about Jedec and vendors. Thanks Tom!
cc_ds
Posted: 26 Nov 2019 at 5:35am |
I found a part from On Semiconductor: CAT24C64HU4I−GT3 In the datasheet they show a recommended land pattern. There the EP pad dimension is larger than the max values. In the same datasheet they also reefer to another document. And there they write:
Posted: 26 Nov 2019 at 9:51am |
Some electronic semiconductors generate more Heat than others. Therefore, the mfr. will recommend a larger thermal pad than nominal.
This happens a lot in Texas Instruments recommended patterns. Listen the mfr. |
cc_ds
Posted: 27 Nov 2019 at 3:26am |
The part I'm looking at is a EEPROM, very low heat dissipation. On Semiconductor: CAT24C64HU4I−GT3 The reasons you list above are a good argument to use nominal values. I find it surprising why manufacturer would recommend EP pad size larger than max value. Would you recommend to use the manufacturer recommended land patter for this part?
Posted: 27 Nov 2019 at 9:06am |
The component mfr. creates a reference design to test the circuitry and heat flow.
They also create a PCB with multiple land patterns and run shock, vibration and thermal cycle tests. The last part on the PCB is the land pattern they recommend. Not every mfr. does this, but how do you know which one did. Since IPC never created any test boards to validate the 7351 guideline for solder joint goals there is no conclusive evidence that the solder joint goals in the guideline are optimized for the best assembly attachment. However, there was a lot of highly educated guesses but after taking the IPC-J-STD-001 training course and CIT certification, I found out that 7351 does not adhere to the J-STD-001 solder joint goal acceptance for assembly. So, I tend to use the mfr. recommended pattern, hoping they ran the necessary tests so that my PCB has the best performance. IPC-7351 is good for when the mfr. does not provide a recommended pattern. Also, I always use the recommended pattern for all connectors and non-standard packages. |
