  New Posts New Posts RSS Feed - New Template Request: TH parts with offset leads
emj_rnrg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote emj_rnrg Quote  Post ReplyReply Direct Link To This Post Topic: New Template Request: TH parts with offset leads
    Posted: 01 Jul 2025 at 7:21am
Can you add a new template for through hole devices with offset leads? An example would be a 3 terminal TH potentiometer where one of the leads is offset on the Y Axis.
I am sure there are other devices besides pots that have this style of footprint.
I can get close with what's there, but they are 2 terminal devices and it's a bit of effort to add the third pin.
Thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:10am
These are non-standard packages that need to be created in FP Designer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote emj_rnrg Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 51 minutes ago at 5:01am
Thanks for your reply Tom- guess I need to learn how to better use the manual editor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 44 minutes ago at 8:08am
FP Designer is quite powerful and it only takes 5 minutes to create a non-standard footprint.
You can create non-standard footprint in Excel and import into the Designer.
Complex BGAs
Customize pad stacks
Quickly create RJ-45 connectors
