New Template Request: TH parts with offset leads |
emj_rnrg
Topic: New Template Request: TH parts with offset leadsPosted: 01 Jul 2025 at 7:21am |
Can you add a new template for through hole devices with offset leads? An example would be a 3 terminal TH potentiometer where one of the leads is offset on the Y Axis.
See 3059Y (https://download.siliconexpert.com/pdfs2/2024/8/8/17/31/30/991364/bos_/manual/3059.pdf) as an example. I am sure there are other devices besides pots that have this style of footprint. I can get close with what's there, but they are 2 terminal devices and it's a bit of effort to add the third pin. Thank you!
Posted: 03 Sep 2025 at 8:10am |
These are non-standard packages that need to be created in FP Designer.
emj_rnrg
Posted: 04 Sep 2025 at 5:01am |
Thanks for your reply Tom- guess I need to learn how to better use the manual editor.
Posted: 04 Sep 2025 at 8:08am |
FP Designer is quite powerful and it only takes 5 minutes to create a non-standard footprint.
You can create non-standard footprint in Excel and import into the Designer. Complex BGAs Customize pad stacks Quickly create RJ-45 connectors |
