  New Posts New Posts RSS Feed - New 2016 Solder Joint Goals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2019 at 7:33pm
There is a Pas Size Round-off in the Preferences or the "Terminal > Settings" tab.
Change the Pad Size Round-off to 0.05 or whatever you want.
5not4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 5not4 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 7:41am
Hi Tom.
What is to be considered the starting point for the toe? Lead length? Or landing pad length? Nominal, max?
I haven't been able to locate any documentation that indicates where this starting point is. I don't have a copy of the IPC-J-STD-001 yet. Hope to have that soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 7:53am
IPC-J-STD-001 clearly states that the Toe solder joint goal should be a minimum of 25% of the Terminal Height or 0.50 mm, whichever is greater.
Look in the Tables.
lsday View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2019 at 7:47am
I do want to change the pad round off to be 0.05. Where would I do that globally? For all packages?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2019 at 7:57am
Preferences > Terminals > Corner Concave > Settings > Pad Size Roundoff
As soon as you select another Terminal like "Cylindrical End Cap" you will get a notification:
Apply Setting Changes to all surface mount terminals? Yes or No
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsday Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2019 at 8:05am
Awesome! Just did it. Thanks Tom!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2019 at 8:07am
Don't forget to change Through-hole too.
Preferences > Terminals > Through-hole > Pad Size Round-off.
Thumbs Up
ted.brinc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ted.brinc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 2:58pm
I don't see a solder joint goals download anymore.  Is the methodology obsolete?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2023 at 3:04pm
It's on your computer in the directory folder:
C:\Program Files (x86)\PCB Libraries\Footprint Expert 23\Documents
File name - Footprint Expert Surface Mount Families.pdf
This page was generated in 0.578 seconds.
