New 2016 Solder Joint Goals |
Page <12 |
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 6061 |
Posted: 11 Sep 2019 at 7:33pm |
There is a Pas Size Round-off in the Preferences or the "Terminal > Settings" tab.
Change the Pad Size Round-off to 0.05 or whatever you want. |
5not4
Posted: 13 Sep 2019 at 7:41am |
Hi Tom.
What is to be considered the starting point for the toe? Lead length? Or landing pad length? Nominal, max? I haven't been able to locate any documentation that indicates where this starting point is. I don't have a copy of the IPC-J-STD-001 yet. Hope to have that soon.
Posted: 13 Sep 2019 at 7:53am |
IPC-J-STD-001 clearly states that the Toe solder joint goal should be a minimum of 25% of the Terminal Height or 0.50 mm, whichever is greater.
Look in the Tables. |
lsday
Posted: 24 Sep 2019 at 7:47am |
I do want to change the pad round off to be 0.05. Where would I do that globally? For all packages?
Posted: 24 Sep 2019 at 7:57am |
Preferences > Terminals > Corner Concave > Settings > Pad Size Roundoff
As soon as you select another Terminal like "Cylindrical End Cap" you will get a notification: Apply Setting Changes to all surface mount terminals? Yes or No |
lsday
Posted: 24 Sep 2019 at 8:05am |
Awesome! Just did it. Thanks Tom!
Posted: 24 Sep 2019 at 8:07am |
Don't forget to change Through-hole too.
Preferences > Terminals > Through-hole > Pad Size Round-off. ![]() |
ted.brinc
Posted: 07 Sep 2023 at 2:58pm |
I don't see a solder joint goals download anymore. Is the methodology obsolete?
Posted: 07 Sep 2023 at 3:04pm |
It's on your computer in the directory folder:
C:\Program Files (x86)\PCB Libraries\Footprint Expert 23\Documents File name - Footprint Expert Surface Mount Families.pdf
Page <12 |
