  New Posts New Posts RSS Feed - Multiple Same Footprint Name
kwgilpin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kwgilpin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2013 at 9:21am
Yes, a new column in the FPX file titled "part name suffix".  The "part name suffix" column would be unique (i.e. different from your Notes column) because FPE would automatically append its contents to the end of the part name.  This solves the problem of user-generated suffixes being deleted when you regenerate the library names.
Does that make sense?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2013 at 9:28am
Yes, it makes sense, but when the user selects the Radio Button for "Add Thermal Tab to Footprint Name" that suffix will automatically be transferred to the FPX file "Footprint Name" column.
It's automatic.
When you create a single part or batch build the entire FPX file the new suffix will be in the name.
I'm seriously considering updating all of our QFN, SON footprint names to add the Thermal Tab suffix once the new radio button is implemented. Then I can do a "Tools > Regenrate > Footprint Name" and it's automatic.
lalexman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 4:34am
Is it possible have that Radio button include the other parameters that you have discussed above ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 9:37am
Let me explain...
In the V2013 release there will be 2 new on/off Radio Buttons for -
  • Add Thermal Tab data to footprint name (only for parts with Thermal Tabs)
  • Add Lead tolerance data to footprint name (only for parts w/Gull Wing leads)
QFN Examples of adding Thermal Tab data:QFN50P600X600X100-41 rename to
QFN50P600X600X100-41_T365 = Thermal Tab size is 3.65 mm square
QFN50P600X600X100-41_T365X200 = Thermal Tab size is 3.65 mm X 2.00 mm rectangular
SOP Examples for Lead tolerance data:
SOP65P490X110-8 rename to
SOP65P490X110-8_L38X68 = Lead size is 0.38 mm minimum and 0.68 mm
What other Radio buttons do you want (specifically list them for our programmers)?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 10:16am
Body Size max (x and y) on any device, lead size Max(x and y)  on any device,   Lead distance end to end on any device that the leads are larger then the body, bga pad size, DFN pad center to center spacing.
Basically what I am looking for is enough info in the footprint name to see quickly if the footprint matches the manufacturers device spec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 10:33am
Unfortunately, IPC only recommends footprint names to be created with elements that solder to the PCB.
The Lead Span, Pin Pitch, Pin Qty, Lead Width & Length, Ball Size, Thermal Tab size, Lead tolerance.
The only exceptions to this rule is the component Height becasue it affects the 3D model name and BGA because Memory Chips have the same package size for various memory limits, 4GB, 8GB, 16GB, 32GB, etc.
i.e.: there is not any component package dimensions in the IPC naming convention. IPC approved the to add the Thermal Tab and Lead tolerance suffix extensions as optional data to reduce duplication.
The User can easily edit the Footprint name in the FPX file to whatever you want. It only takes a couple seconds to add any additional data to create customized footprint names.
The future feature modules the "Package Editor" and "Footprint Editor" will have custom footprint names that will apply to 50% of all packages in the industry.
Example: Component Family _ Mfr. Name _ Mfr. Part Number
This does not include any component package dimensions and there are no duplicate footprint names. Maybe every footprint name should follow this non-standard package convention as component manufacturers are producing non-standard parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 10:57am
So it sounds like  are you saying you can add everything I suggested except body size ?
I realize you want to be IPC compatable but why is adding an option to a name we the users might need a problem ?
Yes we can add it to the FPX file but that does not work in batch mode and adds more time to creating a footprint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 11:03am
Manually changing (customizing) the Footprint Name in the FPX file works perfect in Batch Mode.
There are too many people who want too many different customized options to add to the program GUI. This makes the User friendly GUI and makes it complicated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lalexman Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 11:09am
You asked
"What other Radio buttons do you want (specifically list them for our programmers)?
I responded to ones I though you could add based on your statement plus the body size that is not IPC approved and you cannot add.
So you are not going to add any other options to the radio button then the two you mentioned above  ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kwgilpin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2013 at 1:04pm
This isn't entirely true.  As soon as you select "Tools -> Regenerate Library -> Names" from the menu system, all custom names are destroyed.
This is why I was suggesting a new "Part Name Suffix" column be added to the FPX databases.  When told to regenerate names, FPE would attach the contents of this column to each part name.
