  New Posts New Posts RSS Feed - Multiple Librarians Edit Same FPX
GrungyRemnant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GrungyRemnant Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 8:04am
The old LP Wizard that Mentor bought was able to do this.  We kept the library file on the server and everyone in the company that was creating parts would have them added automatically to this single library file.  It could be viewed by everyone in real time as well.
It seems that the file would be opened only when needing to write the data.  PCB Library Expert Pro seems to keep the files open at all times (or something like that) preventing multiple people from accessing it.  Last access overwrites everything.
I'm not saying there wouldn't be the possibility of collisions, but we never experienced it and it worked well enough. The cost was similar to PCB Library Expert Pro.
Regards,
Chris
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 8:09am
We like suggestions and we know what you need and agree with you.
It's just difficult to create a text editor that allows multiple users to simultaneously edit text without overwriting each others entries.
In the CAD world, the only way they allow multiple PCB designers to collaborate on the same database is to "partition" the file and then eventually bring it back together again. So in reality, multiple people are not really working on the same database. They are each working on a section and they cannot enter into any other section, just the section of their allocated specific partition.
So I need a different example that we can use as an example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 8:16am
We're exploring the possibility of updating the v2016 release so that files will get marked/checked out, and when this happens they go in read-only mode for everyone else. I'm not sure exactly how this will pan out, but it's one thing we're considering at this point. Your feedback is appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2015 at 1:39pm
One of the things that we may introduce with V2016 is direct access to POD to allow the user to compare their BOM with the maser database of millions of part numbers and then batch build the parts for your PCB Layout using your personal preferences.
i.e.: POD would be your main library repository that you have continuous access to. This way you have access to all the content updates and new data instantly. Multiple users can access POD simultaneously.
Since we're adding schematic symbols, enhancing footprint design with new features like irregular shape pad geometry and enhancing 3D STEP, the future FPX file has to change and unfortunately the file size is going to grow to accommodate all the new features. However, the SQL database on POD can easily manage millions of parts simultaneously with zero degradation. The search & find speed is off the charts.
Think of POD and the SQL database of the future as your personal library repository. POD is currently growing at the rate of over 10,000 new part numbers a week and that is going to steadily increase over time.
Of course you can still download parts to your personal FPX file but the speed will not be as fast as a SQL server with redundant backup systems.
Oregon101 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oregon101 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2015 at 4:10pm
I just sent an email...when will you have schematic symbol support?  This will be a great tool to purchase for the Allegro/Cadence tool.  Thanks again for this effort.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2015 at 4:13pm
Alpha version is planned for release in Q1 2016.
cioma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cioma Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 7:15am
Gentlemen,
As I understand FPX in a text file so just use version control system (e.g. SVN) and you'll get your (semi-)concurrent access. The chance of data loss would be close to zero. Besides you'll get a bunch of nice features (e.g. history, comments, forking/merging etc).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2015 at 8:13pm
Multiple Librarians cannot simultaneously access the FPX file.
You need to build al new parts in a new FPX file. Then create the parts to CAD tool. Then import the new FPX file into the company master FPX.
That's the way I would do it.
