  New Posts New Posts RSS Feed - Multi-component Footprint When Small Changed
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Topic: Multi-component Footprint When Small Changed
    Posted: 05 Jun 2025 at 9:17am
We took several months to create the JEDEC library for the MO, TO, MS, DO series.
The JEDEC was one of the first libraries we created.
When you have package dimensions in an FPX file and you add new package dimensions, Footprint Expert will throw a warning that the package dimensions already exist and ask if you want to add a duplicate footprint.
After creating the JEDEC FPX library, we downloaded over a million datasheets and entered all the package dimensions into the JEDEC library and not one manufacturer package dimensions matched JEDEC. Altera was the only manufacturer that had package dimensions that were close to the JEDEC dimensions.
So the question is, why would we continue to support a JEDEC library when no component manufacturer uses those dimensions?
Emilien38 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Emilien38 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2025 at 2:29am
Hello Tom,
Thank you for your replying.
However, in the SOT23, are the component functions swappable between manufacturers?
Do you need to create a unique footprint for every SOT23 manufacturer?
Yes exactly, component are swappable between manufacturer, so unique footprint shall be created.
Lastly, the ST Microelectronics P/N LD3985 is a BGA, not a SOT23.
LD3985.fm SOT23-5L, isn't it? Ouch
Could we asked to add "JEDEC", "JEITA" or others standard as manufacturer in POD ?
Emilien
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2025 at 8:53am
Package body dimensions that are within a 0.20 mm difference from each other can be combined into a single footprint by taking the average dimensions.
The only problem is a different pin pitch cannot be tolerated.
There's another issue with component manufacturers. With chip components like 0603, there are many vendors and the electronic function can be the same values between manufacturers. You might have an AVX chip resistor but the assembly shop stock is an equivalent value in Vishay. Just because the value is the same, doesn't mean the package dimensions and tolerances are the same.
We would us 'Silicon Expert' as a source to find out all the equivalent vendors and then try to create a master pattern to accommodate all the SOT23 vendors that have identical functions. If the NXP component electronic function is unique and no other vendor has an equivalent function, then you need to single source NXP as your vendor.
However, Silicon Expert has all the vendors with equivalent electronic functions for the same component package.
It's the package tolerances that vary from vendor to vendor. These can be rounded up and down to make them match between vendors.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Emilien38 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2025 at 4:12am
We started building our footprint library without the support of a PCB footprint expert, and we also face several internal constraints:
  • We design boards with a very long expected lifetime (up to 40 years), which means we need to manage component obsolescence over time.
  • For this reason, it’s easier for us to avoid redesigning the PCB when replacing components, as long as they share the same footprint (e.g., SOT23 replaced by SOT23).
  • We use some components with multi-source MFRs/MPNs, and the EMS is free to choose the source they prefer.
-            Our Altium component library is managed by a small team, so it’s more efficient for us to keep the number of components and footprints to a minimum.
Given these constraints, we’re unsure how best to manage footprints for multiple components sharing the same package.
For example, with SOT23-3 components, generic name, MFR/MPN equivalent, FootPrintName according to pcblibraries
Generic Name
1
2
3
https://www.pcblibraries.com/
Manufacturer
Manufacturer Part Number
Manufacturer 1
Manufacturer Part Number 1
Manufacturer 2
Manufacturer Part Number 2
Manufacturer 3
Manufacturer Part Number 3
Footprint (internal)
Footprint 1
Footprint 2
Footprint 3
MULTI
BAV199
Nexperia
BAV199-QR
Diodes
BAV199Q-13-F
ON Semi
SBAV199LT1G
SOT95P230X110-3N_I
NEXPERIA_SOT23
SOT23-3P91_290X240X120L52X44
SOT23-3P95_292X237X111L42X43
Vishay
BAW56
Nexperia
BAW56,235
Nexperia
BAW56,215
Vishay
BAW56-HE3-08
SOT95P230X110-3N_I
NEXPERIA_SOT23
SOT23-3P95_290X240X115L40X40 ??
Diodes
BAV70
Diodes
BAV70Q-7-F
Diodes
BAV70Q-13-F
Rohm
BAV70HYFHT116
SOT95P230X110-3N_I
SOT23-3P91_290X240X110L40X44
SOT23-3P95_290X280X130L45X42
Nexperia
BSR14
Nexperia
BSR14,215
SOT95P230X110-3N_I
NEXPERIA_SOT23
Onsemi
BSS138L
ON Semi
BSS138LT3G
ON Semi
BSS138LT1G
SOT95P230X110-3N_I
Nexperia
BSS84AK
Nexperia
BSS84AK,215
Nexperia
BSS84AKVL
SOT95P230X110-3N_I
SOT23-3P95_290X230X110L30X43
MULTI
BC847B-Q
Nexperia
BC847B-QR
Diodes
BC847BQ-7-F
ON Semi
SBC847BLT1G
SOT95P230X110-3N_I
NEXPERIA_SOT23
Nexperia
TL431A
Nexperia
TL431AFDT,215
Nexperia
TL431AQDBZR,215
TI
TL431AQDBZRQ1
SOT95P230X110-3N_I
NEXPERIA_TO-236AB
SOT23-3P95_292X237X112L40X40
                              Table : 1
NEXPERIA_SOT23
= SOT23-3P95_290X230X110L50X45 ??
 Pcblibraries naming conventions :
For the first line of the table 1, there are three multi-source parts. This means that these three footprints must be exactly the same. Many companies use multi-source components to manage the supply chain without issues during the assembly process.
Manufacturer
Footprint pcblibraries
Nexperia
SOT23-3P95_290X230X110L30X43 ?? (NEXPERIA_TO-236AB)
SOT23-3P95_290X230X110L50X45 ?? (NEXPERIA_SOT23)
Onsemi
Diodes
TI
Rohm
Note: On PCBLibraries.com component from Nexperia seems to have NEXPERIA_SOT23 Casecode instead of TO-236AB (except TL431A) ? Why Nexperia doesn’t have a generic footprint name like SOT23-3P95_290X230X110L30X43 ?Ouch
Question is : All of they footprint are compatible for assembly ? Only one footprint can be created with the worst case dimension? There is a difference about the pitch with “diodes” footprint with 40µm less. Angry
One difference is the length and height of the body which have an influence only in the 3D body (we used max 3D body with additional margin, so not a big issues)Tongue
It should be very interesting for us (and other companies?) to link these footprints and maybe to add some acceptable tolerance (+/-100µm ? or 5% for some criteria) to check the compatibilities in order to generate only one footprint if possible.
Same thing here : with SOT23-5
pcblibraries Name
Manufacturer
Manufacturer 1
Manufacturer 2
Footprint 1
ST
LD3985
ST
LD3985M33R
SOT95P280X145-5N
SOT23-5P95_290X280X145L35X42
SOT23-5P95_280X295X145L45X40
onsemi
NCP730ASN500T1G
ON Semi
NCV8730ASN500T1G
ON Semi
NCP730ASN500T1G
SOT95P275X140-5N_I
SOT23-5P95_300X275X110L40X37
TI
OPA188AIDBV
TI
OPA188AIDBVT
SOT95P275X140-5N_I
SOT23-5P95_290X280X145L45X40
onsemi
NCV20061
ON Semi
NCV20061SN3T1G
SOT95P275X140-5N_I
                     Table : 2
Note: On PCBLibraries.com, the ST LD3985 seems to have an incorrect case code: "SOT23-5" instead of "SOT23-5L".Ouch The listed footprint SOT23-5P95_290X280X145L35X42 appears to be incorrect — it seems closer to SOT23-5P95_280X295X145L45X40.
Same question here: the footprint provided by ST shows lead dimensions that are 0.2mm smaller How should we handle this?
(Sorry for this big post)
Thank you for your help.
Emilien
