  New Posts New Posts RSS Feed - Most, Nom, Least Environment - Tab Menus
RLS2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLS2004 Quote  Post ReplyReply Direct Link To This Post Topic: Most, Nom, Least Environment - Tab Menus
    Posted: 29 May 2012 at 4:58pm
I'd like to compare footprint dimensions, comparing M, N, L environments. When I switch environments the window changes to display component dimensions.
Would it be appropriate to remember the tabs in use instead of jumping to Component dimension tab?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2012 at 9:43am
To compare Least, Nominal and Most pad sizes and their differences, I recommend that you open 3 sessions of the PCB Footprint Expert.
I hope you use 2 LCD monitors.
