  New Posts New Posts RSS Feed - Modify Library Expert Outputs or Export Terminals
Eng. Jesus Mora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eng. Jesus Mora Quote  Post ReplyReply Direct Link To This Post Topic: Modify Library Expert Outputs or Export Terminals
    Posted: 29 Apr 2015 at 1:07pm
Is there a way we can modify what comes out in the outputs for pads or Altium Designer, because right now all the mechanical layers that get exported are locked, is there a way to modify what goes on each layer?
Also is there a way we could export the terminal outline layer to pads or Altium? it would be of great help if we could get a layer with that info exported.
Thanks
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2015 at 4:35pm
The parts are built as is.
Once they're in the tool (PADS or Altium), you should be able to do anything you want to with them.
I'll take a look at exporting the terminal outline.
This page was generated in 0.184 seconds.
