  New Posts New Posts RSS Feed - Mapping Silkscreen Outline to Body
JJonas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJonas Quote  Post ReplyReply Direct Link To This Post Topic: Mapping Silkscreen Outline to Body
    Posted: 11 Apr 2015 at 10:43pm
You are offering to choose whether to use Max, Min or Nominal body size when mapping silkscreen outline. However, this feature does not work for THD components. For example, you are not asking to enter min and max values of length and width for DIP packages, Headers, PGA packages and TO-220.
Let's compare PGA and BGA packages. For BGA package you ask to enter min and max values for D (length) and E (width), while for PGA you only ask for max values. Hence for PGA packages you can map silkscreen outline to maximum body size, but you are not able to map to minimum or nominal size. This leads to library inconsistency. Can you please explain why it is done the way it is done?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2015 at 12:09pm
We'll be going over every component family in the next 3 weeks to insure that they all follow the same rules and guidelines. This will be released in V2015.11 the 1st week of May.
This page was generated in 0.484 seconds.
