  New Posts New Posts RSS Feed - LocalCommErr - How to Fix
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: LocalCommErr - How to Fix
    Posted: 14 Jul 2017 at 1:07pm
If you get this error, it's an easy fix. Just try the solutions below and contact us if your issue is not resolved.
The license server has encountered a problem:
LocalCommErr
Program will continue to run with limited license options.
  1. Sentinel / LDK License Manager was stopped. Usually, a simple computer restart will take care of this. If not, go to My Computer (right-click) > Manage > Services and re-enable the Sentinel service.
  2. The drivers on a client (or server) are obsolete or have become corrupted. You can tell if by pointing a browser on each machine to the Admin Control Center: http://localhost:1947/_int_/diag.html - if you get an error when trying to load this page, or if the “Run-time installer and Package” are not 7.80 or newer, or if they mis-match, install the latest drivers from here (see "Sentinel Run Time Installer" at this link):  http://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=305
  3. Firewall change and/or lockout. Network license only. Could be Windows firewall or another third party (Norton, McAfee, ZoneAlarm, etc). Fix: open Port 1947 on both client and server to both TCP and UDP traffic.
  4. Server IP address changed. Network license only. Try to use the steps here to configure an IP address:
    http://www.pcblibraries.com/products/fpx/userguide/default.asp?ch=74
RonaldSmith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RonaldSmith Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2020 at 3:20am
Thank you for giving such kind of information, it is really helpful to me and also tried on my computer and it's working.
This page was generated in 0.578 seconds.
