  New Posts New Posts RSS Feed - Line Properties Grayed Out - How to Change?
NeilVPeers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilVPeers Quote  Post ReplyReply Direct Link To This Post Topic: Line Properties Grayed Out - How to Change?
    Posted: 13 Oct 2016 at 2:00am
In creating a footprint for a right angle LED I wish to be able to tweak the position of the legend detail.
On selecting the Layer and then the line in question I find that the properties are grayed out and cannot be modified.
Is it possible to do this and if so how please?
Many thanks
Neil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2016 at 3:09pm
Legend lines are auto-generated from your Component Dimensions and your Preferences.
You cannot edit them unless you use the "Drafting" feature to add 8 different types of Drafting Lines that you can insert into any part. i.e.: turn off Legend and manually add your own markings.
Any shape, any size, any location, any rotation, any layer...
