  New Posts New Posts RSS Feed - Library/Part Name prompt used in a build.
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Topic: Library/Part Name prompt used in a build.
    Posted: 28 Feb 2014 at 12:53pm
When I go to create the footprint, there are two prompts for library name, and one for part type name that I cannot fill in.   I do not understand this at all yet.  Jeff is aware of this question.  But others may benefit when the answer is finally known.
chrisa_pcb View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote chrisa_pcb Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2014 at 2:32pm
Part Type Name should be greyed out in a multipart operation. In a single part operation, it’ll be the part type name.
Library Name at the top is what the .p/.d or .asc will get named to. The Library Name below the output is the name of the binary library and only applicable when Auto Import is selected. Until then, it should be greyed out.
This page was generated in 1.895 seconds.
