  New Posts New Posts RSS Feed - Library Expert Pro Translators
arendhagedoorn2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arendhagedoorn2 Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert Pro Translators
    Posted: 04 Jul 2018 at 7:44am
I've just installed the "Pro" 2018.05 version of LE.
Now there are only 2 translators, Allegro and 3D STEP.
Is that because of a new policy or am I overlooking something?
Best,
Arend
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2018 at 8:04am
Select "Help > Installed Options" and you can select from 24 CAD tools.
3D STEP is default with all CAD tools.
JonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2018 at 10:41am
3D Step is not one of my options, is it supposed to be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2018 at 10:49am
When you select any CAD tool, 3D STEP is the primary export.
When you create your first library part you must select the "Translator" drop-down and select the 3D STEP checkbox to turn it on.
We are releasing V2018.06 tomorrow and it fixes this issue. You can now select a CAD tool and when you create your first part, the CAD tool will be open and 3D STEP checked by default.
i.e.: if you want to turn off 3D STEP you must uncheck the box.
Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2018 at 10:53am
Jon, I'll contact you offline to clarify.
