  New Posts New Posts RSS Feed - Library Expert 2017.14 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.14 Released!!
    Posted: 15 Jun 2017 at 5:06am
Version 2017.14 was just released!!
NEW / ENHANCED:
  • FP Designer:
    • Added new Pad Stack Manager feature to “Pattern” Solder Mask for Thermal Pads
FIXED:
  • Main Toolbar:
    • Fixed an issue when Restore Down the main toolbar icons did not wrap
  • Calculator:
    • SODFL component family:
      • Micro-miniature versions only produced Legend outlines on one side
      • 3D STEP Model will now take into account if the pins have been Mirrored and adjust the Pin 1 marker appropriately
    • SOFL component family:
      • The pin qty. in the footprint name was stuck on 6 regardless if it was 3, 4, 5, or 8 pins
    • DIP Socket component family:
      • Fixed an issue that prevented the use of round terminal leads
    • Column Grid Array (CGA) component family:
      • Updated the solder joint goal periphery from 0.00 to 0.10 mm to match IPC-7351C
  • FP Designer:
    • Round parts: Silkscreen Legend was updated from rotation 90 degrees to 0
  • 3D STEP:
    • Molded Body component family will now shrink the Physical Body (not including Leads), if there isn’t enough room to place the leads at their minimum size
  • Allegro:
    • Fixed an issue that was causing bottom-side pad stacks not to translate properly
    • Fixed an issue with excluding the courtyard crosshair
  • EAGLE:
    • Fixed an issue with chamfered pads and associated copper
  • KiCad:
    • Fixed an issue with standalone Legend arcs not coming over
  • PADS Layout:
    • Fixed an issue with FP Designer via pad stacks. The Flood Over Thermal Relief Inner Diameter was the same value as the Drill Size and was throwing an error message.
This page was generated in 0.407 seconds.
