  New Posts New Posts RSS Feed - Library Expert 2017.13 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.13 Released!!
    Posted: 22 May 2017 at 11:55am
Version 2017.13 was just released!!
NEW / ENHANCED:
  • Updated all Terminal Lead-Form images in the Calculator and Preferences
FIXED:
  • Calculator:
    • Fixed an issue with the Pin Rename feature: once you rename pins you were unable to rename them again
    • Updated footprint names for:
      • Oscillator Side Concave
      • Molded Body
      • Oscillator J & L lead
      • SOFL Diode, IC & Transistor
        • DIOSOFL
        • ICSOFL
        • TRXSOFL
  • Preferences:
    • When changing Pin 1 pad shape in one location, did not change all locations
  • 3D STEP:
    • Fixed an issue with Molded Body 3D model scaling
  • License selection / default:
    • Under certain conditions, a previously expired evaluation license interfered with the full Pro license
  • Documentation:
    • Updated - IPC-7351C (Proposed) Solder Joint Goal Tables v1.5.xlsx
      • Added the new Terminal Lead-Form images
    • Updated – Surface Mount Component Families.pdf
      • Added Terminal Lead-Form images to pages 36 & 37
    • Fixed 6 typos – IPC-7351C Land Pattern Naming Convention.pdf
      • Molded Body - PKGM + Lead Span X Body Width X Height + L Lead Length X Width
      • Oscillator J-Lead - OSCJ + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Width
      • Oscillator L-Lead - OSCL + Pin Qty. + P Pitch _ Body Length X Lead Span X Height + L Lead Length X Width
      • Diode SOFL is now DIOSOFL
      • Transistor SOFL is now TRXSOFL
      • IC SOFL is now ICSOFL
