  New Posts New Posts RSS Feed - Library Expert 2017.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.10 Released!!
    Posted: 07 Mar 2017 at 3:21pm
Version 2017.10 was just released!!
ALERT! If you are using a personal FPX file you must MANUALLY update 4 solder joint goal settings for IPC-7351C > Preferences > Terminals. If you are using the default preferences, then there is no need to update anything.
Preferences:
  • LEAST Density Level, Side Lead (Concave), Pitch <=0.40 mm had incorrect values for HEEL and SIDE
    • HEEL & SIDE value was -0.70 mm and changed to -0.07 mm
  • LEAST Density Level, Side Lead (Concave), Pitch > 0.50 and <=0.65 mm had incorrect value for SIDE
    • SIDE value was -0.70 mm and changed to -0.07 mm
  • MOST Density Level, Outward L Lead, Pitch > 0.40 and <=0.50 mm had incorrect value for HEEL
    • HEEL value was 20.00 mm and changed to 0.20 mm
  • MOST Density Level, Rectangular End Cap, Size <= 0.50 mm, TOE
    • TOE value was 0.60 mm and changed to 0.06 mm
NEW / ENHANCED:
  • Library Expert License:
    • New 12-month maintenance license is now available! Purchases of new licenses now get all updates, regardless of software version, for a full year
FIXED:
  • Unique Part Viewer - updated the unique part viewer
  • Fixed a graphics display issue for UHD 4K monitors
  • Calculator:
    • Saving component dimensions to FPX did not get the “Type” inserted and unable to retrieve the data
    • Axial Lead: Fixed an exception error when clicking in the Pitch cell
    • SOL terminal density levels not responding to pitch dimension in Preferences
    • Fixed a typo in SOL terminal mislabeled as Gull Wing
    • Fixed an issue with SOL solder joint goals were not properly set to IPC-7351C
    • Removed Contour Courtyard from Chip, MELF and Side Concave 2, 4-Pin component families
  • Library Editor:
    • Fixed an issue when importing Excel spreadsheet data the Logical Description was not coming in
  • Preferences:
    • LEAST Density Level, Side Lead (Concave), Pitch <=0.40 mm had incorrect values for Heel and SIDE
