  New Posts New Posts RSS Feed - Library Expert 2017.09 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2017.09 Released!!
    Posted: 22 Feb 2017 at 8:51pm
Version 2017.09 was just released!!
NEW / ENHANCED:
  • V2017 FPX File Format:
    • Going forward, all saved FPX files will be upgraded to 2017 format
    • Your V2012 FPX file will automatically be upgraded when you save your FPX file to V2017 format
    • V2017 FPX files are not backward compatible with older versions of Library Expert
    • Highly recommended that all team members upgrade to V2017.09 at the same time
  • Library Editor:
    • Updated FPX file format to accommodate unique/complex packages
    • This makes for easier viewing and creation
    • See this video for more details
  • Parts on Demand:
    • Added 455 new Unique packages to POD
  • Calculator:
    • Added “Bead” to the Molded Body component family
    • Added the supporting 3D STEP model
FIXED:
  • Calculator:
    • SOD component family – fixed auto-generated Assembly Polarity Marker
    • Fixed an issue with Chip part courtyards when using 3 place dimensions
  • Library Editor:
    • Fixed an issue with deleting columns at the end of a FPX file and then selecting Datasheet
    • Fixed an issue with Sorting Column data when importing new FPX files into an existing FPX file
  • Altium:
    • Fixed an issue with FP Designer parts with SMD pads on Top & Bottom sides
  • PADS VX:
    • Fixed an issue for 3D STEP with LGA component family
    • Fixed the sizing of the “Type” to map to the Legend Height
  • Xpedition:
    • Irregular Rotated Paste Mask on a thermal tab now rotate properly
This page was generated in 0.327 seconds.
