  New Posts New Posts RSS Feed - Library Expert 2016.11 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2016.11 Released!!
    Posted: 29 Sep 2016 at 10:31am
NEW / ENHANCED:
  • Library Editor:
    • Can now update multiple rows from a single component change
      • If you have the same component dimensions for multiple part numbers
    • Can now Right Mouse Button Copy & Paste into multiple cells from a single text
    • Added a new column to all FPX files at the end called “Date” when selecting “New FPX”
      • When you add a new part to FPX, the Date is auto-populated if the Date column is present
      • When you update an existing part and update FPX the Date will reflect the new Date & Time
      • Existing FPX files must have the Date column manually added if you want this feature
      • If you create a New FPX and don’t want the Date column, RMB > Delete > Column
    • Updated SM, BGA, TH and Sample FPX files with a Date / Time column
FIXED:
  • Calculator & FP Designer:
    • Positioning of rotated symbols and keep-outs.
    • Self-correction for circle symbols where user data has been incorrectly entered
    • Self-correction for removal of duplicate symbols that occupy the same space
    • Dimensional values for Nominal dimensions are passed from Calculator to FP Designer
    • Fixed a Legend Polarity Dot touching Pin 1 issue for 2-pin parts
    • Fixed an issue with pullback leads. Entering the min/max dimension did not generate the necessary nominal dimension.
    • When adding a FP Designer part with a Thermal Pad to FPX, the program was changing the 50% Paste Mask Reduction to 100%
    • The CAD tool translators were not outputting the Triangle Polarity Marker
  • Library Editor:
    • Fixed an issue with Find/Replace not holding the text when using it multiple times
      • When new text is manually or copy/paste entered into cell use Return key to hold it
    • Fixed an issue with Find/Replace All/Match Case
  • FP Designer:
    • Pin step numbering and pin properties not reflecting unit selection
    • Set the minimum pin increment can now be zero for vias in FP designer
    • Fixed an issue with offset slotted hole solder mask
    • Fixed the drawing symbols and keep-outs shifting around with rotational changes
    • Fixed an issue where the program was not loading the Physical Description until the user selected the Finish tab
    • Fixed an issue with rotating round parts
  • Preferences:
    • Changes to ‘SOD’ and ‘Side flat, concave, convex – pitch = 0’ user preference changes weren’t being saved
  • Polarity Markers:
    • Unable to place a symbol under certain conditions
  • 3D STEP:
    • 3D Model output now has a checkbox option ‘Use .STEP’. If this box is checked, you will get .STEP extensions for 3D model files. If it is not checked, you will get a .STP extension. The default is on but can be set using the Save Entries As Preferences.
  • Allegro/OrCAD PCB:
    • Between builds S002 and S005, Cadence slightly modified the syntax of one of the commands used by the 17.2 scripting. A change has been made to reflect this, but it will BREAK all builds before S005. You *must* upgrade to S005 or later of Allegro/OrCAD PCB after you implement this patch. This will also fix the No DEFAULT INTERNAL issue that people on S005 were having.
    • Added a command which turns off the line merge capabilities of Allegro during Graphic placement, and another that turns it back on when done. This should prevent component outlines from accidentally merging with terminal outlines and causing graphical issues.
  • Expedition:
    • Expedition should now be able to detect whether your part is Mixed, Surface Mount, or Through-hole and set the mount type appropriately
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 11:09am
Just uploaded another build with date tracking of when parts are created/updated in the FPX file. This is a very useful feature, we couldn't wait to put this off for the next release. Highly recommended you get this latest build!
