  New Posts New Posts RSS Feed - Library Expert 2015.14 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.14 Released!!
    Posted: 12 Jun 2015 at 10:18am
NEW:
  • Library Editor:
    • To simplify use, we removed the V2015 XML FPX format and reverted to the FPX legacy format. We will provide PADS p/d files for the "PADS to CAD" translator (available with all Professional licenses) until we add the necessary features for irregular pad shapes.
FIXED / ENHANCED:
  • Calculator:
    • Fixed Radial (Electrolytic) Square Pad with Rounded Corners
    • Changed the footprint name prefix for the DFN Polarized Capacitor to CAPPDFN
    • Fixed issue that was suppressing the Body Outline for the TO-220 Horizontal and Vertical parts
  • FP Designer:
    • Fixed SMD pad stack names with corner chamfer cul (Chamfer Upper Left), cur, cbl and cbr
    • When placing a pad with a pin number that already exists now throws an error message
      • Removed the ability to have multiple pins with the same pin number
    • Non-plated holes were labeled as Thermal Pads. This was updated to Mechanical Pin.
    • Added a new + polarity marker to the Drawing button
  • Preferences:
    • Fixed 3D STEP color edits were not being saved to the User Preference .dat file
    • Fixed changes to Terminal items were not being saved
    • Updated GUI text “Mask” to “Solder Mask” and “Stencil” to “Paste Mask”
    • Fixed an issue with Drafting > Assembly > Include Polarity Markers when unchecking the feature did not produce a closed polygon
    • Fixed an issue with relocating the origin to Pin 1 in the SIP component family
  • 3D STEP:
    • Updated and improved the Chip Resistor model
    • Fixed an issue with the PTH Axial Lead Fuse component lead color for Pin 1 was missing
    • Fixed the Chip > Capacitor, Polarized was not generating a STEP output
  • Allegro:
    • Rotations for symmetrical pad stacks have been oriented properly for right reading pin text
  • Altium:
    • Fixed a problem with donut shapes that were causing the pad stack not to generate properly
    • Fixed a problem with donut shape through-hole pad stacks that was causing the hole to offset improperly
    • Keep-outs for Fiducials and through-hole parts now translate properly
    • Solder Mask for DShape pads is generating properly
    • Fixed DShape pads
  • EAGLE:
    • Updated slotted holes
  • Parts on Demand:
    • Added over 50,000 new parts and updated over 100,000 Logical Descriptions
    • Improved part request process
