  New Posts New Posts RSS Feed - Library Expert 2015.11 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.11 Released!!
    Posted: 28 Apr 2015 at 6:05am
NEW:
  • FP Designer:
    • Added Local Fiducials to the Pad Stack Editor
    • Add Annular Pad Shape
  • Widget Sliders:
    • Separate hole and Pad ID clearance for CapSense Round and Rounded Rectangle button
    • Cut-washer copper attached to Annular (donut) pad for Rounded Rectangle button
FIXED / ENHANCED:
  • Calculator:
    • Fixed the SOT143 Pin 1 pad shapes as they were doubled
    • PTH & NPTH Mounting Holes - Add Annular Pad Shape
    • The SOL footprint name was coming out as SOPL and fixed to SOL
    • Fixed an issue with SOT23 not outputting a Component Outline
    • PTH LED had wrong dimensional picture
  • FP Designer:
    • Fixed Top and Bottom SMD pad stacks for Edge Mount connectors
  • Default Preferences:
    • Added SOTFL to the SOT component family
    • Terminal – Through-hole add Annular Pad shape
    • Fixed settings for the Through-hole Terminal
    • Fixed an issue with Local Fiducial settings for QFP and BGA not adhering to preferences
  • Library Editor:
    • Updated SM, TH and BGA FPX files in the customer downloads section
  • 3D STEP:
    • Fixed Through-hole Header terminal lead tip chamfer was irregular shape
    • Updated the Allegro Import Instructions on the website Help
    • Fixed and issue with SON and QFN with D-shape pads
  • Allegro/OrCAD PCB:
    • Fixed a problem that would cause the program to crash if your 3D Model Directory deviated from your Output Directory
  • EAGLE:
    • Fixed an issue with Rounded Rectangles that were causing them to turn into holes
    • Fixed a problem that caused SMD Pads to not be generated properly
    • Fixed a problem with the rotation of SMD Pads
    • Fixed an issue where the "SMD" commands were replaced by "Hole" commands
  • All CAD Tools
    • Fixed a typo in the CAD tool Translator menus
    • Fixed an issue where some component families were not translating Placement Courtyards: CAPAE, PSON, SOIC, SOJ, SOP, SOT23, SOT223, SOTFL, TO (DPAK)
  • Widgets:
    • Fixed issues with Round and Rectangle Buttons
    • Linear Slider, added radius corners
    • Radial Slider, fixed CAD tool interface
