  New Posts New Posts RSS Feed - Library Expert 2015.06 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.06 Released!!
    Posted: 12 Jan 2015 at 12:34pm
Version 2015.06 was just released!!
NEW:
  • Calculator - New Contour Placement Courtyards for the SMD component families that meets new IPC-7351C standard and creates additional placement area for small components
FIXED / ENHANCED:
  • Help > Check Version:
    • Feature was broken in V2015.02 - .05 and fixed in .06
  • Calculator:
    • Graphic issue in the SODFL when changing units from millimeters to mils
  • User Preferences:
    • The text “USR” was coming out in the Footprint Name Suffix even though the text was deleted from the cell
  • FP Designer:
    • Pad Stack query properties. User can change any value and select the OK button then the pads disappear in the footprint.
  • PADS Layout:
    • Various problems when attempting to use Direct Import to import only a Part Type or only a Part Decal. It’s still suggested that you create both when outputting a part from FPX to PADS.
  • CR-5000:
    • A problem that was causing bottom layers to be duplicated for surface mount parts
  • Expedition:
    • A problem that was causing crash on Build Part
    • Flange Mount (TO-220) Horizontal Thermal Pad was not outputting in the correct location
  • 3D STEP:
    • Created a new Micro SODFL when the component height is less than 0.50 mm
