  New Posts New Posts RSS Feed - Library Expert 2015.05 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2015.05 Released!!
    Posted: 13 Dec 2014 at 1:41am
Version 2015.05 was just released!!
NEW:
  • Calculator:
    • When reordering pins and Pin 1 is in the upper right, the program will now automatically rotate the part to put Pin 1 to match the Zero Orientation rules
  • Viewer for Unique Packages:
    • The V2015 XML FPX format for highly unique (complex) packages can view the footprint prior to building it
FIXED / ENHANCED:
  • Calculator:
    • 2-pin parts - the placement courtyard was being pushed out ½ the thickness of the silkscreen line width on Chip and Molded Body footprints
    • Pin reorder not working properly for SOT’s with pins that have been renamed
    • Component orientation not in accordance with the setting preference when pin 1 is relocated
  • Library Editor:
    • Column auto-size is only performed when a library is opened
  • FP Designer:
    • Manufacturer prefix not updating correctly in FP Designer when manufacturer is reassigned
    • Problem in pad stack manger with changing pad on assembly option.
    • Rotating oblong pads with offsets.
  • Altium Designer:
    • Option to use “Existing Library” did not work correctly
  • PADS Layout:
    • Updated the Ref Des Line Width = % of Height to round off to the nearest whole mil unit or nearest 2 places in metric
    • Fixed an issue with polarity markers not displaying properly
  • TARGET 3001!:
    • Rounded Rectangle Pad polys should now be placed properly
    • Polarity markers should now show up and now has the proper radius
    • Layer Naming is now provided for those layers which can be mapped to custom layers
  • CR-5000:
    • Added an option for Pad Naming. The values are either CR-5000 Style or IPC-7351 Style. IPC-7351 style is new and will provide an output similar to the pad stack naming.
  • 3D STEP:
      • Fixed some bugs in the calculation of the Axial Resistor model
      • Added 3D STEP for the new 2-pin DFN Polarized Capacitor
