  New Posts New Posts RSS Feed - Library Expert 2014.10 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2014.10 Released!!
    Posted: 11 Sep 2014 at 1:30pm
Version 2014.10 was just released!!
NEW:
  • The .10 release is now available to all Lite Users as the default download
    • You must Opt In to our newsletter to receive V2015 releases - opt in here
  • Calculator:
    • Added two new component families “Resistor” & “Fuse” to the Side Concave (2, 4 pins) calculator
    • Added a new component family “Fuse” to the MELF calculator
  • 3D STEP
    • Added 3D STEP models for the new Calculator component families
FIXED / ENHANCED:
  • Code Update - removed new code that was causing Library Editor issues
  • Calculator:
    • Turning off all layers in the Layer Display dropdown threw an Exception Error
  • EAGLE:
    • Issue that was including Paste Mask and removing Solder Mask for local fiducials to be included should none exist
  • Altium/PADS:
    • Issue that was causing the .ASC files not to import. This bug fix will also add back in the Family (BGA, etc.) if importing ASCII into PADS
    • Issue that was causing a batch build to drop part type names from the parts
    • Issue when dealing with missing pins
  • P-CAD/Design Spark/Pulsonix:
    • A layer issue that was preventing the file from loading in PCAD
  • Library Editor:
    • Issue when deleting rows in an FPX file
    • Issue when pasting an item from one file into another that contained that same item
    • Sample.fpx was updated
    • Issue with editing the Manufacturer cell
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2014 at 10:40am
We just posted the 2014.10 release, and it is now available for download.
