  New Posts New Posts RSS Feed - Library Expert 2014.03 Released!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nick B Quote  Post ReplyReply Direct Link To This Post Topic: Library Expert 2014.03 Released!!
    Posted: 03 Jun 2014 at 10:07am
Version 2014.03 was just released!!
NEW:
  • PADS Layout Translator Feature:
    • Added a new “p/d ASCII Filter” that allows the user to translate PADS p/d files to any CAD tool format –
      • Change drafting line widths
      • Change silkscreen and assembly Ref Des height
      • Change layer assignments
      • Adjust or remove Polarity Dot
      • Adjust or remove drafting items
FIXED / ENHANCED:
  • PADS:
    • Parts in which pins have been removed and the numbers were then reordered now translate properly
    • Issue preventing the proper line width for rectangles from being used
  • Eagle:
    • Added an option to allow the 3D Height to be divided by 1000 and used as the 3D Line Width. This is applicable when using the Eagle ULP for post processing to allow it to strip the height into a tool like SolidWorks.
  • 3D STEP:
    • Fixed an issue that was preventing Rotate Axis from displaying when using the standalone 3D STEP translator
    • Various models for families have been updated so they display properly in the CREO line of tools. These families are: SOTFL, SOL, SOT23, SOT143, and SOT223
  • PADS p/d Translator:
    • Fixed a problem that was causing Part Type Gates to be read improperly by the parser.
  • General:
    • All medium Font Translator Form UI issues
