  New Posts New Posts RSS Feed - Library Editor Index Categories
lorymg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorymg Quote  Post ReplyReply Direct Link To This Post Topic: Library Editor Index Categories
    Posted: 12 Mar 2015 at 2:25am
When in Library Editor active categories and I want to be indexed on any column recur all categories.
Is there any way to index individual categories?
Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2015 at 5:58am
Did you try using the "Categories" icon in the toolbar?
When you select (double click) any line item in Categories, the program will remove all other Categories and the Library Editor will only display the Category that you selected.
Also, can have 100% control of the Categories content. There is a semicolon ";" in the Physical Description. Everything to the left of the semicolon appears in the Categories list. Relocate the semicolon anywhere you want or add any additional text before the semicolon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorymg Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2015 at 6:20am
When I open a library FPX and I click any category, I can not do a search for riordinado column (ascending / descending).
As soon as I click on any column (Footprint Name, Description Phisycal, Case Code, etc.) Reappears throughout the library with all categories !!
I would like to reorder only one category and not the whole library!
Thank You
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2015 at 6:28am
Please submit a New Feature Request here -
I will go ahead and ask the programming team if they can start implementing this feature for the next V2015.10 release.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lorymg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 6:34am
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 3:02pm
I'm sorry to say that the programmers have reported that this issue cannot be fixed in the current V2015, but it will be fixed in V2016 when we do a code rewrite.
