  New Posts New Posts RSS Feed - Land Pattern Names Based On Pad Style
jmeinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Topic: Land Pattern Names Based On Pad Style
    Posted: 13 Dec 2018 at 1:01pm
Is there a setting or preference to identify the pad style in the name?
Most of library contain rectangle type pads. We are now considering using oblong pads on all parts, but can NOT change existing cells.
From what I can tell both rectangle and oblong pads use the same naming convention.
I am looking for a way of identifying what style pads are being used without manually changing the name.
Hope this makes sense,
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 1:09pm
You can recreate an entire library regardless of how many parts are in your FPX file.
Open Preferences.
Save the Preferences under a new name to indicate the Pad Shape.
In Preferences > Components change the pad shapes to Oblong
In Console Preferences > Overwrite Footprint Name Level > enter 3 characters that indicate Oblong example: OBL or OBG or OB or O
Then Batch create your entire library and O will be the last character in the Footprint Name.
It's really easy to do and you can create dozens of different libraries this way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmeinert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2018 at 1:11pm
Thanks Tom.
