L huh? |
SteveD
Joined: 30 Oct 2013 Location: San Diego Status: Offline Points: 240 |
Topic: L huh?Posted: 18 Dec 2014 at 3:03pm |
I'm confused about the library naming convention for those auto generated footprint names. When I spec a lead length of .4 to .7 mm it generates a name that ends in L30. Why not L55 as I told it in the nominal column. Sometimes it comes out as expected - just enough to make one superstitious.
Reading the naming convention sheet, it says this is where the environment goes. I don't see anything in the environment that would suggest L30. Is this a bug or my misunderstanding?
Joined: 05 Jan 2012 Location: San Diego, CA Status: Offline Points: 5985 |
Thanks(1)
Posted: 18 Dec 2014 at 3:06pm |
L30 = the Lead Tolerance The Nominal Lead Length may be the same but it's the Tolerance that makes the pad longer or shorter. |
