  New Posts New Posts RSS Feed - L huh?
L huh?
SteveD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveD Quote  Post ReplyReply Direct Link To This Post Topic: L huh?
    Posted: 18 Dec 2014 at 3:03pm
I'm confused about the library naming convention for those auto generated footprint names.  When I spec a lead length of .4 to .7 mm it generates a name that ends in L30.  Why not L55 as I told it in the nominal column.  Sometimes it comes out as expected - just enough to make one superstitious.
Reading the naming convention sheet, it says this is where the environment goes.   I don't see anything in the environment that would suggest L30.
Is this a bug or my misunderstanding?
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tom H Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2014 at 3:06pm
L30 = the Lead Tolerance
The Nominal Lead Length may be the same but it's the Tolerance that makes the pad longer or shorter.
This page was generated in 0.500 seconds.
