KiCAD solder mask margin
stairhill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stairhill Quote  Post ReplyReply Direct Link To This Post Topic: KiCAD solder mask margin
    Posted: 28 Jun 2019 at 3:28am
Playing with LE Pro to try generating KiCAD footprints, mostly excellent results.  We use copper defined pads so I define solder mask aperture 0.05 bigger than the copper pad, this appears as expected in LE but not in the exported KiCAD footprint.
LE needs to add (solder_mask_margin n.nn) to the pad definition, where n.nn is the margin, when the solder mask setting !=0.00 in LE
This page was generated in 0.969 seconds.
